TwinTurbo.NET: Nissan 300ZX forum - Start cheap
Start cheap
300ZMang
on July 28, 2008 at 8:51 PM
Valve seals?
posted by Driggers
on July 28, 2008 at 09:35 AM
do a compression test first and replace your pcv's, worth a shot.
Valve seals?
Driggers
09:35:59 07/28/08
Nope! If you are blowing the dipstick out, it almost
kkrofft (OH)
12:50:03 07/28/08
Re: Nope! If you are blowing the dipstick out, it almost
Driggers
15:15:33 07/28/08
Piston rings require a complete teardown. No point
kkrofft (OH)
19:14:08 07/28/08
have you checked compression?
aliaZ
12:50:49 07/28/08
Re: have you checked compression?
Driggers
15:19:49 07/28/08
need to run a compression check at a minimum
aliaZ
17:05:50 07/28/08
Re: need to run a compression check at a minimum
Driggers
17:31:58 07/28/08
I wouldn't rule out the turbos just yet
aliaZ
09:49:32 07/29/08
Start cheap -
300ZMang
20:51:33 07/28/08
